Propane Furnace
Propane Furnace
Hi Guys
I am trying to find info on a Frasher-Johnson furnace. Do you no of a web site that I might go to too get info like manual and trouble shooting tips and a break down on parts. Any help would be great.
Thanks again Mark
Thanks again Mark
Frasher-Johnson
The model number is P-HDD12N06901A, serial number EABP000332, manufacture number 9352459304. The problem is the air line going from the secondary air pressure switch to the bottom of the coils is plugged where it hooks to the bottom of the coils. I cant get into that bottom piece to unplug it. I have a jumper wire where the pressure switch is, it seems to be running fine, is that pressure switch even necessary?
Sincerely Mark
Sincerely Mark
if it is the switch i think you are referring to, it detects water build up from faulty drainage and opens
what exactly is plugged?
i have drilled out rust from psi switch ports... not sure what you have there
