Trane blower won't come on
Old 03-05-05, 05:04 PM
slotmoshen
I have a trane package. Either an xe 1000 or xe 1200. The blower does not come on when heat is turned on. When air is on the blower works and when fan is turned to on instead of auto it works. What could be my problem? If it is an unlit pilot light, where would that be located? Thanks
Old 03-06-05, 06:04 AM
mattison's Avatar
Does it start heating with the blower in the on position?
Old 03-06-05, 06:20 AM
slotmoshen
Blower not working
Hot air does not come out with blower in the on position.
Old 03-06-05, 06:30 AM
mattison's Avatar
You very well could be out on a safety or you've got a part that's went bad. Is the filter clean? Are all the returns and supply vents open and getting good airflow with the blower on?
When was the last time it was cleaned and safety checked by a pro? This should be done at least every other season.
Old 03-06-05, 07:53 AM
scottg's Avatar
Location: Wilmington, NC hurricane magnet of the U.S.A.
When the blower is running can you get heat by raising the thermostat ?
