YorK Stellar Plus Gas Furnace Blower Problems
Old 03-07-05, 05:51 PM
BoxerDad
Hello All,
When running my furnace blower in the "Fan On" mode, no heat, it runs for approximately 5 minutes then shuts down for approximately 1 minute and starts running again.
When I run the heat and have the fan on the "AUTO" mode it runs fine throughout the heating cycle.
I ran my central air with 'Fan on Auto and this also caused the fan to cycle off.
It seems to be related to the motor running on High Speed.
Any help wpould be much appreciated. By the way this is the second Blower Motor in 13 years, with the first being repalced after just 4 years.
Need help with this , can't believe it's another motor.
John
Old 03-07-05, 07:57 PM
Jay11J's Avatar
Have you tried changing the blower motor speed?
If it does the same thing when you change the fan "on" speed, then it maybe the control board?
If it doesn't do it when you change the speed, then it's the motor.
Ductwork undersized? Filter kept clean?
