New Water heater, old chimney
I want to replace my electric water heater with a gas one. I have an old oil burner chimney flue available. Is it possibly, if its cleaned, that I could vent it out the old chimney, maybe run small double walled pipe up it?
I would have the chimney inspected to make sure that it doesn't have any leaks in it. Using a draft gauge is probably the best way to test it; make sure there is a cleanout to clear out the chimney from broken bricks, mortar, suet.
Your idea of a flue liner is probably the most economical way to go to in providing adequate draw for the gas appliance.
