no pilot on lennox furnace
Old 05-14-05, 08:50 AM
Brock
hello,
having trouble keeping pilot lit on lennox furnace.
Tried a new thermal couple but it did'nt work
Old 05-14-05, 06:18 PM
Grady's Avatar
Received 23 Votes on 21 Posts
Pilot problems
If the pilot flame is blue & envelopes the thermocouple the pilot burner should be fine. The problem could be the gas valve itself. If the pilot is weak, yellow, or white, remove & clean the pilot assembly.
Old 05-16-05, 09:05 AM
Brock
Grady, how would I know if it were the gas valve? are they expensive and could I install it myself? thanks brock
Old 05-16-05, 06:06 PM
Grady's Avatar
Brock
Lennox is notorious for using special parts, only available to Lennox dealers. Do you have a voltmeter capable of reading dc millivolts? Are you sure the gas valve uses a 30 mV thermocouple? This is the normal voltage out of a thermocouple but some valves require a higher voltage.
Old 05-16-05, 10:08 PM
Brock
Grady,
thanks for your replys, no unfortunatly I don't have a volt meter, and no I don't know what kind of thermal couple, so looks like I'll be calling a service tech.
Brock
Old 05-17-05, 06:52 PM
Grady's Avatar
Gas valve
If you can get me some numbers off of the gas valve (make & model minimum) maybe I can find out some particulars. A bad, new thermocouple is not unheard of.
