2 vents one chimney
Old 08-07-05, 04:09 AM
2 vents one chimney
I have a oil fired furnace and a oil fired hot water tank vented into the same chimney. What is the proper way to set up the draft damper, only one damper for both or one for each? And how should the damper be set up? The furnace runs from October to thru April.
Old 08-07-05, 10:16 AM
Grady's Avatar
Received 23 Votes on 21 Posts
Two appliances
There shoud be a draft regulator on each appliance.
