Bryant Gas Furnace
Old 10-13-05, 05:36 AM
L
Bryant Gas Furnace
Hi Everyone,
I need help on a Bryant Gas Furnace(not sure of the model #)this one is older with a hot surface igniter.I can get the fan to come on but nothing else.I replaced the igniter and the thermostat.Not sure what else to do.Thank You!!
Old 10-13-05, 06:57 AM
Jay11J's Avatar
If the flame is not turning on after the ignitor glows, it could be not getting gas.
Is the gas valve turned on? do you hear it click after the ignitor gets hot?? Check to see if you have power going to it.
Old 10-13-05, 08:52 AM
L
I'm not getting the igniter to get hot.I am correct in assuming that the igniter has to get hot for the gas valve to kick on,right??Could it be the control board??Not really sure!Thanks again.
Old 10-13-05, 12:21 PM
Jay11J's Avatar
Yes, the ignitor has to glow before the gas turns on.. Maybe the pressure switch is keeping from turning on.. Flue vent maybe blocked? Take a reading to see if you are getting power to the ignitor control
Old 10-14-05, 04:35 AM
L
If I'm not getting any power to the igniter than what could the problem be??
Thanks!!!
Old 10-14-05, 07:56 AM
Jay11J's Avatar
Are you not getting 24 volts or 120 volts to the ignitor modulor?
If no 24 volts, then trace back on pressure switch.. limit switch.. safety switch..
if one of those switches are tripped, then you need to find out why it tripped.. DO NOT bypass any of these safety switches.
Do you have a small inducer fan on the system?? That has to be running first before the ignitor come son?
If no 120, may want to check the power going to it.. wire ok? Wire come undone somewhere?
Old 10-17-05, 11:23 AM
L
Checked,not getting power to the igniter.All wires seem to be ok.Could it be the control board???
Old 10-17-05, 12:31 PM
Jay11J's Avatar
Is the power going to the modular from the safety switches?? (Switches all closed?)
Old 10-17-05, 05:53 PM
Received 1 Vote on 1 Post
Did you leave your meter in the HSI connection when t'stat calling for heat for at least 1 minute. Takes time to get to that stage. Also do you hear an audible sound from gas valve after t'stat has been on for 1 minute or so?
Old 10-24-05, 04:46 AM
L
Turns out it was the circuit board after all.Thanks to all for the help!!!
