Gas furnace pilot lite
Old 10-17-05, 02:47 AM
K
I have a 25 yr. old {at least} gas furnace. The furnace runs fine with plenty of heat but everytime the unit shuts off the pilot light goes out. I am having no trouble relighting the pilot. Could the thermocouple need to be replaced?
Old 10-17-05, 04:06 AM
mattison's Avatar
I would start by cleaning the pilot assymbly good. Blowing compressed air through it will help. If the t-couple is more than a few years go ahead and replce it while you have the pilot assymbly apart.
Old 10-17-05, 03:25 PM
P
kpg,
It sounds like maybe the thermocouple? Sometimes older drafty homes can cause that too....
Have you considered a new furnace? Today’s units are more efficient than your 25 yr old furnace by a long shot! With the projected price of natural gas this winter, it might make sense for you to go with a new furnace.
Last year I replaced my old furnace with +90 ComfortMaker and it made a huge difference in my natural gas usage this past winter. Even an 80% unit will save you a ton of money when compared to your old dinosaur.
Phil
Old 10-17-05, 06:30 PM
Jay11J's Avatar
I agree.. think about a new one.. My gas usage went down almost half last year with a new furnace.
I had a 37y/o Air Temp 120,000BTU , and put in 2-stage Trane VS 80,000BTU.. House is even in temp as well.
Old 10-18-05, 05:36 AM
K
Thanx for the responses. I had the furnace looked at last year by a heating contractor before I bought this house & they rated it at 82%. I have considered a new furnace, but the expense has me wary. I have approx. 1800 sq. ft. of living space. I don't have a clue what a new furnace would run me. I'm going to change out the t-couple today & see what happens.
Old 10-18-05, 07:10 AM
Jay11J's Avatar
Umm.. 82%??? No! The 80% has a small inducer fan the control/pulls the exhaust from the furance. More likely that furance is maybe 60% at best.
Is it a G- series? Lot of those had heat exchanger that has failed on them.
Also, lot of times those old furance were way oversized for homes.. For your home your size, i'd say a 60 to 80k, and I'd guess your current system is over 100k BTU.
Keep it in mind.. it will pay it self off when you get a new one.
Old 10-18-05, 09:51 AM
K
I changed the t-couple, but it did no good. So, I'm back to square 1. The plate on the furnace says Health -Aire by V&H Industries out of Buffalo. You're right Jay, it's rating is 100,000 btu's. How can I tell if it's a g series? In any case, it's time to call a service tech.
Old 10-18-05, 01:20 PM
K
Well, I guess I may have spoken too soon. I went & bought a can of compressed air & removed the fitting for the pilot assembly from the valve. I blew it out thru the tubing & restarted the pilot. I ran the furnace through 2 cycles & the pilot has stayed on. Guess I'll keep an eye on it & see what happens. For less than $15. I may have solved the problem, knock on wood. Thanx to all for you're help.
Old 10-18-05, 05:39 PM
Jay11J's Avatar
Glad to see you got it going..
Never mind about the G-series.. I thought you had a Lennox at first.
