Garage Gas Furnace=No go
Old 11-05-05, 10:27 AM
fireweedfour
Good Day;
Grinell Excello Gas Forced Air Garage Hot Air Furnace.
I've just installed the gas line to the garage with the assitance of my wonderful assitant (my wife). I've hung the used Excello from the ceiling. Installed the Bvent chimeny as per code.
I can get the pilot light lit and I have 120 to the transformer and circuitry. I must be missing something because the unit wont fire. I could have the circuitry incorrect but I haven't been able to find a source on the net to confirm the wirering.
I have a thermostat wire hooked into the transformer curcuit. When I cross the thermostat wire I get a humming but after 20 seconds it stops.
The fan doesn't come on and the burner is refusing to fire.
I have replaced the thermocouple with no success.
I would greatly appreciate any and all help as winter is arriving here in central Alberta. I'm trying to get my garage turned into a shop so that I can accomplish so many of the projects that I have been unable to do in the summer.
Help.
Cheers,
Rob in Alberta
Old 11-05-05, 05:52 PM
Grady's Avatar
Received 1 Vote on 1 Post
Pilot only
It could be as simple as having the gas valve still on "pilot" instead of "on". When the thermosat is calling for heat, do you get 24 volts to the gas valve?
If you do, you could have a bad gas valve. Has anyone checked the gas pressure to be sure it is within the furnace manufacturer's specs?
Old 11-05-05, 06:51 PM
Is this a new unit? If so did you use existing make up box or try to wire yourself? You shouldn't have to do anything more then connect supply voltage & run low voltage wires. What are we missing?
Old 11-05-05, 09:09 PM
fireweedfour
Garage Gas Furnace= No Go
I'm new to furnaces in regards to installing them. But I did install the gas line from the house to the detached garage. Thread all the pipe and pressure test the line. When it gets to the electrical of it all this is where I'm not so certain...
The unit is a used one and I'm not certain of the age but I'm guessing at least 15 years (for $60 I'm thinkin it was a fair trade, if it works).
I've been able to figure out the manifold to the "set, pilot, on, off" level.
The wirering was in place except for the thermostat wirering. When I shorted the thermostat wires the manifold would hum for about 20 seconds. I thought that this was calling for gas but not providing it. Then the huming would stop. I'm certain that the heat exchanger is to heat up before the fan comes on.
As mentioned I changed the thermocouple as it was possible that it wasnt' working. Then after a few attempts I tapped the manifold to possibly loosen a stuck valve. No luck.
The transformer... is it giving 24 volts?, good question. I wired the thermostat wirering and I'm getting milli volts through that wire. I'll check directly off of the transformer.
Would anyone have a wirering diagram that may be helpful for me?
Again any and all input is appreciated.
Cheers,
Chilly Rob in Alberta
