Auto Heat not coming on
Old 11-06-05, 08:56 AM
kaner
My thermostats is set to auto but the heat is not coming on whenever the house temp goes below the set temp. the A/C is working the way it suppose to. I have changed the thermostat but heat is still not coming on. what else can be wrong ? please help... thanks
Kane
Old 11-06-05, 05:48 PM
Grady's Avatar
Kane
Is this a gas or oil fired furnace? Make & model might be of some help.
Old 11-06-05, 08:14 PM
Jay11J's Avatar
Does the heat work when you turn the fan to "ON"?
If so, then it maybe the blower motor (heating speed)
Old 11-12-05, 08:53 AM
kaner
It is a gas furnace (TAPPAN), and thermostat is Hunter (programmable model #44360). The furnace (heat) does come on according to the temperature on thermostat while manual "ON". Both furnace and fan does not come on while on "AUTO".
Thanks for your help.
Kane
Old 11-12-05, 04:54 PM
Bonehead's Avatar
Kane
It sounds like the thermostat is wired wrrong. Normally on "auto" the fan and heat come on. The fan only comes on when the heat comes on...or, in other words, 'automatically' comes on when the heat comes on. And in the "on" position, the fan just runs all the time, whether or not it is calling for heat. That's why it says "on". The fan is always on. It sounds like 2 wires are reversed in your programmable. Did someone install this thermostat after the furnace was already installed with a different thermostat?
