honeywell digital thermostat probs
Old 11-24-05, 10:32 PM
tae's Avatar
tae
tae is offline
hey all. i have a honeywell digital thermostat going to a natural gas heater outside. The thermostat sometimes just goes blank, like it looses power. At first, i thought it might be the cable(and still might be) so i went outside to check it. there was a break in the line that was wire nutted and taped, but i cut off the ends about 6 inches and redid them. still same problem. i redid connections inside the unit as well. the heater still seems to works even when the thermostat is blank.could the thermostat be going bad, or should i replace the whole wire run, or could it be something in the unit outside? any advice appreciated!
Old 11-25-05, 05:27 AM
Jay11J's Avatar
What model # is the t-stat?
When you said when it went blank, the unit still was putting out heat?
Checked the battery on the t-stat?
mattison's Avatar
Does the stat have a common wire or does it simply run off the batteries ??
Old 11-25-05, 08:34 AM
Grady's Avatar
Received 23 Votes on 21 Posts
T-stat problems
I don't like to see splices in wire runs. Replacing the thermostat wiring will certainly not hurt & may help. Use 18 gauge wire & unless the wire is in a conduit, make sure the wire is rated for sunlight resistance. If the thermostat has batteries, you might want to try new ones. When replacing the batteries, clean the holder with an eraser.
Old 11-25-05, 03:03 PM
tae's Avatar
tae
tae is offline
the model is ct2700a vr
doesn't have batteries.
has 4 wires
i found a link to one here (mine was not refurbished,and about 2 yrs old)
http://www.virtualreturns.com/hw_CT2700A.html
the heater still goes even when the l.e.d. is blank. whether it actually functions correctly i could not say.
Old 11-25-05, 03:12 PM
Grady's Avatar
T-Stat
I would have to guess the stat is bad. Running new wire is certainly worth a try.
Old 11-26-05, 06:33 AM
Jay11J's Avatar
I agree, it's a bad t-stat then.. If it went blank, and shut of the system. then it maybe other problems..
But it's your stat.. That style is no longer made.
Old 11-26-05, 10:30 AM
tae's Avatar
tae
tae is offline
thanks.
new t-stat and wire it is.
Old 12-06-05, 05:17 PM
tae's Avatar
tae
tae is offline
o,k..today ran new wire (18/4)40 feet, and hooked up new t stat (ritetemp 8035c). Old tstat had w,r,g,y(no batteries)...i connected new wires to new tstat... w to w, g to g, r to rh, and y to the c. put new batteries in,turned it on, and everything worked. brought temp up to set point of 76. then i tried the temp override at 78. the house got a mild funny smell, and heater/ac isnt working. if i take out the batteries, i get nothing. the unit is a carrier forced air ac/heat combo. any ideas?
Old 12-06-05, 06:57 PM
tae's Avatar
tae
tae is offline
update
o,k,ktalked to a ac/heat guy..he said by my connecting the y to the common (gotta love ritetemp instructions) i probably blew the tstat and the transistor? outside. sound about right?
Old 12-06-05, 06:59 PM
Grady's Avatar
Wiring
The Y wire needs to go to Y. You will probably need another wire to go to C.
Old 12-06-05, 07:10 PM
Grady's Avatar
Blown
He probably said or meant to say "transformer". Good possibility. We must have been typing at the same time but you type faster than I.
