Flame sensor
Old 12-12-05, 06:42 PM
mrzukerman
Flame sensor
I have a Evcon/coleman furnace and I need to remove the flame sensor and clean it.But I am unable to locate it and find how to get it out. This unit has a eletric ignition . Thanks
Old 12-13-05, 02:45 AM
H
Are you sure it has a flame sensor? Some models use the hot surface ignitor for flame rectification.
Old 12-13-05, 10:46 AM
mrzukerman
The only thing I'm sure of is that it doesn't work.
Really though yes it does have a flame sensor, and I spoke with a service tech that said it sounds like it needs clean or replaced, do to the problem I have just can find a way to access it, and unable to talk with the tech again for a few days. Thanks
Old 12-13-05, 08:55 PM
Grady's Avatar
Received 23 Votes on 21 Posts
Flame sensor
Look for a single wire going to a rod with a porcelain insulator. This rod is the flame sensor. If you post a model number of the furnace, it may be of some help in helping you locate the sensor.
