ignition lockout
ignition lockout
hello i have a carrier furnace model # 58RAV downflow its about 10 years old. When i wake up in the morning the house is all cold and the furnace will not come on the code was 14 ignition lockout. so if i flip the switch on the side the furnace fires right up and works all day no problems. What should i do? any help will be appreciated.
well last year when i bought the house I had a service tech. come out becuase it was not working and he replaced a switch he said that the switch went out because the filter needed to be changed. but i don't think he cleaned any thing. what needs to be cleaned? and what is the flame sensor?
A flame sensor is a metal road that has a single wire to it.. The sensor is surounded by flame in the burner area. use the green scoure pad to clean nit.. Do not use sand paper
