oil heat tank
oil heat tank
any info appreciated : we moved into a house and was wondering (1) is it safe to have a oil heat tank in your basement ? we have two , one is not hooked up one is which has pvc pipe running from the tank to outside the house where it can have a hose inserted to fill the tank up (2) there are no guages on the tank or inspection seals . Is this legal or safe ? were not using them presently but need answers asap were in ohio and running out of wood for the fire place !
Yes, it's safe to have them in the basement.. As long there is a pipe going outside to get air you are fine.
since you are new to this.. be best to call the oil company and see if they have a GOOD oil service tech, that way they can go over everything to make sure it's up to par, and the burner is cleaned, filters changed.
