Blower Motor
Blower Motor
Hello,
I have an ICP Furnace (age unknow). The blower motor asbly. is making noise on start up. Sounds like the fan inside the asbly. is banging against something. My questions are, (1) I, consider myself a pretty handy guy and seeing that i can buy the asbly. on line, does this part also require a gasket when mounting it back onto the furnace. (2) are there any other things i should be aware of before tackeling this job.
All help is appricated
Thanks
Pete
Thanks
Pete
Received 40 Upvotes
Blower motor
If you are replacing the whole blower assembly, it is a pretty easy & straight forward job. No gaskets are required. You might want to pull the blower & try to figure out what is making the noise. No need in replacing the whole assembly if the noise is due to a motor with bad bearings. Simply replace the motor. The same idea with the fan itself.
