Furnace will not lite
Received 0 Votes
My furnace is about 5 or 6 yrs old. Mauf. by goodman. I always run my fan at night for white noise for my son. Anyway, When I woke up this morning I noticed it was running nor did the furnace kick on. I went to check the thermostat and it was set on 68 and the house temp read 66. So I turned thermostat to off for a couple seconds then I turned it back on. I didn't do anything. So I put it back in the off and went down to furnace. removed panel and turned the gas off, and the main furnace switch for 5 minutes. After 5 minutes I turned the gas on, turned the switch on the side of furnace and turned the thermosat back on to HEAT.
I went back down to the furnace and it sounded as though it wanted to start but it just won't spark and ignite.
do you think its my ignitor? If so, How difficult is it to change out for a HVAC rookie, but a very handson mechanical person??
