Ignition Problem Comfortmaker
Old 03-08-06, 10:42 AM
I've got a Comfortmaker furnace with a Honeywell board. The only way I can get it to fire up is to turn the unit on at the thermostat and then go to the furnace and wiggle the ignition/spark wire where is connects to the control board. I've replaced the connection at the end of the wire and have lightly sanded the pin coming from the board.
When I wiggle it, I'll hear the spark and then the furnace will fire up. Do you think I need to replace the board? Anything else I can do? Your help is appreciated.
Old 03-08-06, 04:53 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Ignition problem
Before you replace the board, make sure all grounds are good (clean & tight) & replace the ignition wire. Ignition wires are a lot cheaper than boards.
Old 03-13-06, 05:40 PM
Good thinking. I'll check the grounds. For the ignition wire, would it be the wire itself or will it come with the ceramic piece/metal rod on the end? I took it out and it looks like it's all comes as one unit.
Old 03-14-06, 06:30 PM
Grady's Avatar
Ignition Wire
Usually they come as two separate parts but yours could be made as one piece. Your parts supplier should be able to tell you.
