Lenox G26 Won't Light
Old 03-16-06, 05:22 AM
B
Unhappy Lenox G26 Won't Light
Replaced igniter, and system will sometimes temporarily fire and sometimes (now) won't light at all. I've attempted to manually light with lighter/match and system will not fire .
Thanks In Advance
Old 03-16-06, 05:59 PM
bolide's Avatar
Received 1 Upvote on 1 Post
> I've attempted to manually light with lighter/match and system will not fire.
You can't fool the computer. Is it flashing an error code?
Are the electrical connections to the ignitor tight?
Old 03-16-06, 08:20 PM
K
Is the G26 the one with the blue johnson control? Does it have 24v to it?
Old 03-19-06, 09:57 AM
B
Yes it is,voltage seems to come and go, while monitoring it ignited and ran for about 30 seconds, than shut down. I do have 24v................Thanks for response
Old 03-19-06, 10:11 AM
K
You mean the 24v from the pressurer switch comes and goes? Or the voltage to the gas valve and sparker? I've had a lot of trouble with that board. Needto know if its power in or power out.
Old 03-19-06, 04:26 PM
B
Power at the pressure switch and every where else is present, however the 24v out of controller to switch on gas valve is missing. Like I've stated at times it will light and within 30 seconds cut off. I'm pricing the ignition control assembly at some sites now...........but if you have another suggestion I'd appreciate it.................Thanks In Advance
Old 03-19-06, 07:15 PM
K
Sorry Ithink its the board.
