New cased A-coil and furnace (alignment)
Old 03-21-06, 08:43 AM
P
Re: New cased A-coil and furnace (alignment)
Hi,
I recently had a contractor replace my old Carrier
furnace, etc with lo-end Heil eqpt.
The cased A-coil unit sits slightly akilter on the furnace.
It is flush with the furnace on one side and varies
up to 1/4 " over-the-edge of the furnace in back and
on the other side.
How do the cased A-coil units fit onto the furnace? Are
they supposed to align perfectly?
I've paid the contractor (evidently a mistake on my part,
should've held back something), and am wondering if
this constitutes poor workmanship that might justify
a BBB complaint. As near as I can tell, they didn't do a
very good job except on the plenum, which *looks* good, but
that might be the reason the A-coil doesn't align.
Any/all suggestions/info much appreciated.
Cheers,
Puddin'
Old 03-21-06, 10:56 AM
Jay11J's Avatar
Sometimes, the case may be larger than the furnace itself, and if it's only hanging over by 1/4 of an inch, I won't worry about it.
Are you able to post pictures for us on a photo host site?
Old 03-21-06, 03:01 PM
Mine is flush with the furnace, when i put it together the fit was close to perfect. Is the coil made by heil? If you dont feel air coming out of the seam I wouldnt worry about it. The flange is probably an inch wide so it is sitting on 3/4 of an inch
Old 03-22-06, 07:03 AM
P
I should've mentioned that it is a matching Heil cased coil unit.
I fear my dig. camera is not up to pictures, but I can explain
in a bit more detail.
Viewing from the front, the coil unit is flush on the left side.
Extends about 1/4 " over the furnace edge on the right. On the
front and back, one corner is flush and the other is 1/4" off.
I goofed, should've stood over 'em with a magnifying glass
the whole time instead of walkin' the dawg, doing little
exercises (daily routine).
Thanks,
Puddin'
Old 03-22-06, 07:33 AM
bolide's Avatar
Received 1 Upvote on 1 Post
It's probably as good as can be. I don't see any valid complaint in what you described.
