Matching Heil furnace with Heil recommended (cased) A-coil unit
Old 04-08-06, 10:05 AM
P
Re: Matching Heil furnace with Heil recommended (cased) A-coil unit
Hi,
Does anyone have any idea where I can find the Heil model
# for the Heil-recommended (cased) A-coil unit to mount
on a Heil furnace model N8MPN075B12B1??
I have run searches and searches and about all I've found
is that ICP specs are a hideous mess ...
Thanks,
Puddin'
Old 04-08-06, 04:35 PM
tinner73's Avatar
the coil is actually matched to the condenser. the case is matched to the furnace. what is the issue?
Old 04-09-06, 08:54 PM
P
Yes, both are supposed to match per mnfgr. specs.
The A-coil case is flush on one side, hangs over a bit
on the other side, and is mounted somewhat akilter.
Any idea where I can find the matching specs????
Puddin'
Old 04-10-06, 02:16 PM
tinner73's Avatar
how much is it overhanging?
Old 04-10-06, 08:21 PM
P
About 1/4 ".
Might there be any (any? ANY??) chance that you could
respond to the original query ??? I'll assume not until
you yield evidence to the contrary.
P
Old 04-10-06, 09:03 PM
tinner73's Avatar
1/4"??.......time to step away from your furnace.
as stated before...the evap coil is matched to the condenser. it has nothing to do with the furnace. you can get a cased 3 ton evap in 17" or 20". see.... they are still a 3 ton evaps just different case widths. you can't call Heil and say "i have a 75k btu furnace what sized cased coil do i need?"
Old 04-11-06, 10:05 AM
P
You can't call Heil (ICP) and ask for so much as the time
of day. It's just not "What They Do In Life".
Heil eqpt installed 3-14-06:
Furnace: N8MPN075B12B1
10 SEER Condenser: NAC024AKC3
Cased Evaporator Coil: EPD24B15C2
All 3 components are *supposed* to meet mnfr's
specs for being integrated into a single residential
system.
If you are not aware that cased A-coils are indeed
made to properly fit given furnace model #s,
please, please do not further respond in this
thread.
Puddin'
Old 04-11-06, 02:47 PM
tinner73's Avatar
puddin.......... don't tell me what i know. i could and do install these things for a living. you obviously can't. ok..you obviously have a 2 ton system. first time YOU mentioned the size. is it 14" or 16" wide? either way it's 24k btus of cooling. why do you think it's mismatched? what is your question? what's your problem? is it working? you had about 10 threads before you got this thing. now it's gonna be 10 more? you're worried about a quarter inch? call Heil and see if they make a evap coil a quarter inch smaller....just for you. <--gotta be your contractor.
Old 04-11-06, 08:46 PM
P
I didn't. But you demonstrated ...
>obviously can't.
Sho'ly. Sho'ly. Could that be the problem?
I was dealing only with model #'s ...
Supposed to be 15 1/2.
>mismatched?
I told you. It doesn't fit properly.
Kindly read the lead query in this thread.
Right now it appears to be you.
>is
No way. Check your arithmetic.
>contractor.
I'm worried about a sloppy install. But there aren't any
sloppy installs (in your world). Are there? Are there?? Are
there??? :-)
Some folks respond with answers.
Some folks respond without addressing the query,
just to be responding.
Some folks respond with implied or explicit malice.
S'long,
Puddin'
