thermostat
Old 04-13-06, 07:14 PM
T
thermostat
What would make you loose power to the heat side only of your
thermostat. The a/c works fine. no power when I turn it to
heat.
Old 04-13-06, 09:37 PM
Received 3 Upvotes on 3 Posts
Did you recently replace it....if yes ....you may need to to have jumper between rh & rc
Old 04-13-06, 09:38 PM
Jay11J's Avatar
What kind of system do you have? (Hot water heat and A/C system in the attic?)
Old 04-17-06, 06:19 PM
T
thermostat
I have a tempstar gas pack down stairs (thermostat that is
giving me the trouble is a digital honeywell). My upstairs unit
is an attic furnace and seperate a/c unit. It is working fine.
Old 04-17-06, 06:24 PM
Jay11J's Avatar
You should have a steady power of about 24 volts at all times on R at t-stat. If you have 24 volts, and the display comes an goes, i'd say time for a new t-stat.
Old 04-18-06, 08:32 PM
T
Thumbs up thermostat
Thanks for the advice will pick one up tomorrow and let you
know if its fixed.:
