Alpha CB/28 combi boiler Hot water problem
Hi
I wonder if anyone can help. I had a simular problem about 8 months ago and had a new diverter valve fitted. This problem appears to be a little different in if i do a reset it often rectifies itself or if this fails i just remove the DHW flow switch and replace it then it tends to work for a few hours.
