Converting gas valve
My firnace isa HYDROTHERM HC 145F-V furnace with a HONEYWELL VR8200A2116 constant burning pilot valve,I want to convert to ignition sparking or intermittant pilot burning,what kit or parts are needed or recommended to achieve the above.
There are retrofit kits available, however I would recommend that this is not a DIY project..Best left for a qualified tech. In addition to replacing parts adjustments are necessary.
