Adjust CPH for honeywell T8112
Old 07-05-06, 02:57 PM
J
I have a forced air gas furance with a Honeywell T8112. How do I adjust the CPH on this thermostat so I can lower the CPH? The furance is 90% efficient. The thermostat maintains heat at one degree and turns off and on alot. Was told to lower CPH and furance would not turn off and on so much, maybe like my old thermostat that vary a couple of degrees?
Joe
Old 07-05-06, 05:07 PM
Grady's Avatar
Received 23 Votes on 21 Posts
Cycle rate
Some thermostats don't have a cycle rate adjustment. Almost all do have some kind of adjustment for temperature variance between cycles. If you don't have the book which came with the thermostat, try Honeywell's web site.
