"hissing" sound in Goodman furnace
Old 09-17-06, 09:41 AM
P
I have installed a Goodman 95% efficiency furnace upside down which I'm told is in the counter-flow position. After the combustion fan stops during a normal cycle, water backflows from the secondary heat exchanger into the primary heat exchanger and makes a "sizzling sound" and steam comes out of the burner ports. I have read the directions several times and can't find what I've done wrong.
Any ideas?
Marty
Old 09-17-06, 09:55 AM
B
did you flip the ventor motor? is the condensation trap filling up??
Old 09-17-06, 10:11 AM
P
Talking
No on the ventor motor. That's a good suggestion - I'll give it a try. As far as I can tell, the condens trap isn't filling up, but I'm going to double check that as well.
Thanx!
Old 09-17-06, 05:01 PM
Grady's Avatar
Received 23 Votes on 21 Posts
Sizzling
Some furnaces have a trap which must be filled with water prior to firing.
