troubleshooting whitfield prodigy 2 pellet stove
Old 10-03-06, 08:48 AM
B
Question troubleshooting whitfield prodigy 2 pellet stove
I just installed a new fuel feed motor in my pellet stove and i dont know how to adjust fuel feed rate, it's dumping way too much pellets, i need help!
Old 11-08-06, 05:04 PM
Auger rpm
Be sure and check the auger rpm on the one you replaced with the old one. They come in a couple rpm's usually 1&2 rpms. I think Whitfields run 1rpm? All pellet stove boards have a trim control as well which fine tunes the auger speed. If your trim does not reduce the feed, my guess is that you got the wrong auger motor. Your auger should not have changed pellet flow as a result of changing. JB
Old 02-22-09, 02:59 PM
C
Whitfield Profile 30-2 Auger feed setting
How do I set the Auger feed using the trim board on the bottom of the control panel?
There is a calibration button and a common, auger, conv.fan, comb.fan jacks.
Thanks
