Furnace lights, fan comes on then cuts off too soon
Mom has a model 7670c856 coleman gas furnace, the burner will light, heats, fan comes on, runs about 30 seconds to a minute then shuts off. The burner continues to burn even after fan shuts off, but will go off after a while. The fan unit will not heat the house because the fan will not run long enough. Is this possibly caused by a limit switch, if so which one (high or low)? Please help as she is beginning to get cold.
For now, just leave the fan "ON" for heat..
Sounds like the fan switch is not working like it should.
Part #7710-3281 fan swithc (open85 close105)
http://www.mobilehomerepair.com/ColemanGas.html
