Changing Furnace Blower Speed Whisper Quiet
Old 11-05-06, 09:39 AM
Changing Furnace Blower Speed Lennox Whisper Quiet
I have a 1991 lennox whisper quiet furnace .My scematic & manuel shows a way to change the blower speed on the fan motor plug.It has a fan wire,neutral wire and a heat wire.There are 3 additional optional configerations on plug available.Do I move the red heat wire to the other configurations to increase the speed?I do not want to damage the unit and lennox will not give teck advice and the manuel does not clarify how to properly change the speeds HELP
Old 11-05-06, 03:56 PM
Jay11J's Avatar
Two speed are used on most furnace.
-Heat
-Cool/Fan on
Red most of the time is used on heat, and that the slower speed.
What are you planning on doing? Want more air or less?
Old 11-05-06, 05:04 PM
Jay, I want to increase the air volume.My instruction manuel says to change the wires on the harness plug but does not get specific.I assume the common white wire is not changed nor is the fan wire. There are 3 other optional spaces on the plug that I can reconfiquire but am not sure that I should move the red heat wire in case i damage the circuit board it originates from.?
Old 11-05-06, 05:13 PM
Jay11J's Avatar
I take it you have 4 wires total from the motor itself, and 3 wires from the control?
Can you take a picture of the harness for us?
Old 11-05-06, 05:37 PM
Jay, I will be going to our mountain home tommorrow and will take pictures,sure appreciate your advice as I cannot access information and do not want to make a mistake and damage circuitry.I also have the scematic , I could not understand the correct wiring options.
Old 11-05-06, 06:59 PM
Jay11J's Avatar
Keep us posted, and may not hurt to take a pic of the secmatic.
