Amana gas heater problem.. Please help
Old 12-11-06, 04:50 AM
E
Hello again guys can i get some further help on my
amana air command heater? The igniter is lighting brightly and the burners also light up but after say 3 seconds it shuts off! I changed the flame sensor and i pulled out the temperature sensor which i noticed had some corrosion on it so i cleaned it but it continues to shut off. Some help would be appreciated from this great site..
Old 12-11-06, 05:41 AM
Are you getting a flashing code from the red led located on the circuit board?
I assume your mean limit switch when you say temperature sensor. If you have a meter, this could be a lot easier to diagnose. Check all your ground connections. Usually there is a green wire from the circuit board that connects to the furnace chassis. Remove and clean both surfaces where this wire connects (use sandpaper or emery cloth). Without a good ground connection, the flame sensor cannot work properly. Also check the flame sensor wire, you need a good connection at both ends.
As a test, disconnect the flame sensor and start up the furnace. Does it behave exactly the same way?
Again, your symptoms indicate flame sensor (this can include wires and ground). There is a small chance the board is bad, but everything else must be ruled out first.
If anyone else has something to add, please jump in.
Old 12-11-06, 08:00 AM
E
Amana furnace problem..
Thanks for replying, and i checked everything from the outside such as wires and bad connections. I removed the exhaust fan and made sure it was blowing. I have not checked the inside fins for accumulated dirt but that might be difficult because i cant seem to find where to open it.. I will also try turning it on without the flame sensor even though i put in a new one. Any help please
Old 12-12-06, 08:12 AM
E
Thanks for all of your help i found that the new flame sensor was not plugged in correctly and it started right up. Thanks again for all of your help. Great Site!!!
Old 12-12-06, 01:19 PM
I'm glad everything worked out OK. Thanks for letting us know. I wish more people would do the same.
Old 12-12-06, 04:45 PM
E
No problem and i will make sure that i check up to see if i could help someone..
