Carrier Weathermaker 9200
Hi: This is my first popsting. From what I've read, it looks like a great place
to ask for and offer advice.
I have a Carrier Weathermaker 9200 High efficiency gas furnace. During our first attempt this season to use the heat side, there was a clicking (*wife's description) coming from the attic (attic mounted unit). It stopped when I disconnected the thermo. I am now trying to fire it up again. I have bypassed the thermo for now (connect r & w on the unit term board.The house fan starts. the larger squirrel cage in the unit starts. The black smaller fan does not. No burner ignition. I get a 31 error code. I attempted to run the led diagnostic (rmv red lead, momentarity jump test term and 24vcom) The main unit blower starts, then kicks up to a higher speed, then shuts down, again flashing the 3-1 error code.
Ideas?
Much thanks BB
Ideas?
Much thanks BB
Hi Jay: Thanks for the reply. I'm going to start at the top. Presently, when powered up with the r/w open, nothing is running and the LED is a steady 'on'. Upon closing r/w, the main blower in the 9200 unit (disregard earlier referrence to 'house fan') kicks on. LED blinks 12 (one short, two long). After running for 90 seconds, fan shuts down, LED goes to steady 'on' and an intermittent clinking is heard from a relay on the solid state board. I cannot detect the relay id, but looking at the card with the terminal block on the upper right, the relay is on the lower left.
The code '12' error states, "BLOWER ON AFTER POWER UP (115 vac OR 24 vac) Blower runs for 90 seconds. If unit is powered up during a call for heat (r-w closed)"
Thanks
BB
Thanks
BB
Man.. You got me on that one... It been way too long since I've serviced a Carrier..
You said on earlier post you had code 31, and now 12. What does 31 means?
