Rheem Classic 90 Plus wont ignight about 30% of time
Old 01-10-07, 09:50 PM
P
It has been a mild winter. Have had no issues with this furnace in the 3 winter we have had this house. All of the sudden 2 days ago it is cold in the morning. T-stat is set at 6, room temp is 64. I go down and pull the bottom cover off the furnace (not the top yet where the burner, gas valve, etc is yet) and tape the switch. I cycle the amin power switch. After the board resets the combustion fan comes on. After about 45 sec. the igniter I hear activating but no flame and does not light. I also notice 1 solid green LED and the other flashing 2 times. I pull the top cover, cycle main power again, it lights. Think it is a fluke, put all back togather. This morning same deal, so I pull both covers, it lights again. As it is lit I put the top cover on (cover for burner, etc.) and it goes out. I notice the furnace wants to suck the cover on a but which I assume is a bit normal. So, it is running fine with top cover off today. Any ideas?
Old 01-11-07, 05:32 PM
G
If your combustion air comes from the outside, via a pipe, check it for something clogging it. Would explain the flame going out and the top section being sucked on.
Old 01-11-07, 07:30 PM
P
That makes sense.. I will check it. It is 3 degrees out so I am not sure I want to go on the roof. Any harm running without the top cover for a few days?
Old 01-11-07, 10:26 PM
G
Should be okay. Mine could run either way, but since the builder decided not to draw from the exterior, mine runs fine on the normal air infiltration into the house.
