Cold in Stockton
Old 01-11-07, 08:50 PM
Question Cold in Stockton
I have been using heat a little more often the last month, and now it seems to have stopped. I turn it on, heat & fan, and the fan works for a bit then stops. Then it comes on again , then stops. Fan is in the "on" position and not auto. The heating unit is a Heil, with a Honeywell thermostat. Any tips you may give woud be welcomed. Thank You
Old 01-12-07, 01:37 PM
Ed Imeduc's Avatar
Wink
Need more INFO INFO Just what do you have there furnace ,wall heater ,gas ,oil ,electric??????? Can be the blower motor is bad if it comes on then off
Old 01-15-07, 02:43 AM
Its a furnace, runs central air and heating. How do I check for blower being out and are they an easy item to replace, or do I need a pro?
Old 01-15-07, 09:35 AM
Ed Imeduc's Avatar
Wink
Id say call a tech to check it out . That on and off when you have fan on .Sounds like the blower motor is bad. If you dont have a meter or amprobe and dont know electric. For sure call a tech
Old 01-17-07, 07:09 PM
Any idea on about the cost if it is the blower motor?
