Furnace Filter -- Where is it??!!
Old 01-13-07, 07:43 PM
N
I have a relatively older furnace in my newly purchased home. It is a McDonaldaire furnace. I want to replace the filter but I can not find one where the filters normally are. Can anyone help me by telling where the filter is located? Thanks in advance for any help.
Old 01-13-07, 08:59 PM
G
Usually they are located where the cold air return enters the furnace. Since you just bought the house, it's a good possibility that the previous owner removed it and did not replace it.
Old 01-14-07, 08:59 AM
N
Furnace Filter
Thanks for your input. I have searched around the entire furnace unit and there is no space for a filter to go like in my previous furnaces. On those there was a slit right next to the main unit where the filter slipped in. (a 20x20 filter). On this one there is no gap anywhere. I don't know where to look for it.
Thanks again for the help.
Old 01-14-07, 09:13 AM
logcabincook's Avatar
Ours fits into the access door (top part is the burner access, lower part is the cold air intake access). It was NOT obvious at all, there isn't even a clip. You just fit the filter onto the door.
Old 01-15-07, 05:34 PM
K
If you only have one return. It might be in the grill.
