Beckett/Weil Mclain won't fire after reset...
Old 02-09-07, 12:48 PM
G
I'm not 'new' to Oil furnaces, but not super experienced either, at dignosing things...
I DO clean my own furnace, and replace the nozzle...
We rented out our house, and the tenants called and mentioned the furnace isn't running.... he hit the reset button, and the motor ran, but it did not fire... i'm assuming the 1st thing to check would be:
1. Fuel coming from the bleed valve,
2. if there's fuel, change the nozzle
3. If still doesn't fire, it would be the ignitor?
or is there an easier way to tell?
thanks all!!
Old 02-09-07, 04:23 PM
G
Ah....solved for now...Air in the line ( i did ask if they had run it out....)
if anyone has any thoughts on the above question, they still stand..
thanks all..
Old 02-09-07, 04:34 PM
Ed Imeduc's Avatar
Wink
for sur tell them to not hit the reset button more than 3 times ..... Then stop
The oil filter , clean and reset the electrodes, check the psi on the pump. Every year
# 3 check the transformer
