Rudd furnace codes
Old 02-27-07, 05:48 PM
Rudd furnace codes
Does anyone know what the different codes mean for a 90 plus Rudd drum furnace. The purge motor will start and stop for 4-5 times before burner lights. When furnace finally begins to run, it will only run for few minutes and start the process all over again. Where would you find the pressure switch on this furnace?
Old 02-27-07, 06:55 PM
user 10's Avatar
Received 57 Upvotes on 50 Posts
That model is notorious for bad heat exchangers - call a technician to have it inspected ASAP.
SEE:
http://johnmills.net/hvacshots/pages/drum1.html
http://johnmills.net/hvacshots/pages/drum2.jpg
