Furnace Ground Wire Question?
Old 03-02-07, 06:53 AM
P
I recently purchased a rental property and this past week had a problem with the furnace. It turned out to be a dirty flame sensor but the service tech said the furnace is not grounded. The wire coming from the breaker box only has a white and black wire; no green.
Can go to home depot and buy some 14-gauge (green) stranded thhn and ground the furnace to the nearest copper pipe? Or; do I have to hire an electrcian to run new wire (with its own ground wire) back to the service panel?
Thanks,
Phil
Old 03-02-07, 07:47 AM
To do correctly, run 14ga. 2 wire w/ground from the breaker to the furnace especially since this is a rental and the liabilities involved with having rentals. You could run it yourself though if you feel comfortable.
Old 03-02-07, 09:11 AM
Jay11J's Avatar
I agree, it must be run back to the breaker box.
Old 03-02-07, 05:51 PM
P
Thanks guys........
I'll have an electrician come over and do it the right way since I'm not real comfortable about messing around inside the main service panel; plus my step-son (great-kid) is a journeyman electrician and I'll kick his butt if he doesn't do the job for me. (LOL)
I just thought since there was a 3/4" copper water line running right over the furnace I could ground it to that. Good point about it being a rental property and the liabilities involved.
Phil
