flue insulation
Old 03-08-07, 10:06 AM
H
flue insulation
I recently bought a newly constructed @1 yr old home. The inspector told me that the flue run from the 80% gas furnace in the attic is not code. The horizontal run is @15ft and the veritical run is @8ft. He suggested I insulate the metal flue pipe. He said it would help the economy of my furnace. Is this true? I would have thought it would just keep the condensation to a minimal. I have not seen any threads about insulating a furnace flue, why would I need to do this? What are your thoughts?
thanks,
Hoggman
Old 03-08-07, 05:17 PM
Jay11J's Avatar
NEVER put insulation on a flue pipe!
I'd call the office and talk to a supervisor for the safety of others!
I know some area you must use B-Vent from the furnace all the way to the roof, where some area just use single wall then into a B-Vent up the roof.
Old 03-08-07, 05:36 PM
DaVeBoy's Avatar
Here is something to read:
http://www.neo.ne.gov/neq_online/sept2004/sept2004.wiz.htm
Old 03-08-07, 05:48 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Insulated flue pipe
I'd bet the code says "insulated pipe". B-Vent is considered insulated. But Hector the Inspector hasn't a clue other than what "code" says.
Old 03-09-07, 07:48 AM
H
Then it is a condensation issue. Still don't think I should insulate it - another worry is that it may be putting too much heat into the attic and I worry about mold issues. I will just keep an eye on it this winter and see if I see any water.
Thanks for the input.
Old 03-09-07, 07:52 AM
Jay11J's Avatar
What do you have now?
A single wall vent, or a double wall B-vent? if you got single, then you need to go to the B-Vent.
Old 03-09-07, 01:45 PM
Grady's Avatar
Single wall pipe
Single wall pipe must not go thru an unconditioned space. Pipe running thru unconditoned spaces MUST be B-Vent.
