Pilot wont stay lit
Old 04-12-07, 12:20 AM
N
Smile Pilot wont stay lit
I know it may be the thermocoupler, but is there a temp. fix like cleaning it until the morning when I can get parts?
Old 04-12-07, 03:57 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Thermocouple
You likely have it fixed already but in case you don't, make sure the pilot is strong & wrapping around the thermocouple. If not, remove & clean the pilot burner.
Old 04-12-07, 09:42 PM
N
Pilot wont stay lit
Thanks for your reply. We had a storm start early this morning, and i took the thermocoupler apart, sanded it with fine paper, and re-installed it. I replaced it this morning about 10 A.M. Thanks again for your reply.
Old 12-23-12, 02:46 PM
Hi,my pilot lits up but goes out after i release the pilot button.What will i do to make it stay?
Old 12-23-12, 02:48 PM
Grady's Avatar
If the pilot is enveloping the last 1/3 of the thermocouple, replace the thermocouple. If the pilot is weak, you will probably have to clean the pilot burner.
