wiring furnace & condensate pump
Hello all, I am having a new furnace installed, and will require a pump for the condensate. I have a dedicated power circuit for the furnace, would it make sense to put the condensate pump on the same circuit, or wire it into the general outlet circuit?
Thanks for the help.
Greg
Greg
Received 41 Upvotes
Recepticle
When I install a furnace, I mount a 4x4 box on the side of the furnace & in it put a switch for the service person's use to kill the power to the furnace, & a duplex recepticle on the "hot" side of the switch. One of the recepticles can be used for the condensate pump & the other for a drop light, vacuum cleaner, or whatever the service person may need.
When wiring this box & the furnace, power should go from the breaker, thru the emergency switch, then to this 4x4 box. The emergency switch should be located at the top of the basement stairs or some place where one would not have to approach the furnace to turn off the power in an emergency.
