Reznor F75 natural gas heater
Old 09-20-07, 05:06 PM
R
I have been unable to get my garage heater going despite having two yahoos ($150) come and look at it. I have replaced the gas valve ($100) and the thermocoupler and pilot assembly ($30) I can keep the pilot lit but it will not kick in. what am I missing? I have also placed a new regulator on it ($40). The two wires that go to the thermostat are wired together so it should fire right up. Help me before I pull out the remaining hair on my bald head!
Old 09-20-07, 09:38 PM
F
Received 36 Votes on 28 Posts
There are several possibilities. Wanna send me a round-trip airline ticket and have me come out and troubleshoot it? I haven't worked on anything like that for close to thirty years but I'm pretty sure that with a few hours and maybe some new parts I could get it going.
Seriously, tell us everything that you know about your unit and what the two "yahoos" did and maybe someone here can offer a few suggestions.
Old 09-21-07, 03:24 AM
R
reznor
the first guy said the gas was coming out too fast and put a regulator on it. He also sugested that I replace the thermocoupler and pilot assembly. I did that. The second guy said that the gas valve was bad so I replaced that. This thing still will not fire. I am able to light the pilot and it stays lit, but will not ignite the rest of the burners and start the blower fan.
Old 09-21-07, 10:34 AM
F
Do you have an instruction or installation manual for this unit?
Does this furnace have a blower in it? Is it a conventional forced air furnace or is it a wall furnace? Does it use a 24 volt control circuit or does it use a millivolt control?
Can you post some pictures? Close ups of the wiring and control systems would help.
Old 09-21-07, 11:09 AM
D
Did you download the manual from Reznor like I suggested in the last thread? You're going to need the schematc and a voltmeter to see where the circuit to the gas valve is open.
Old 09-24-07, 08:22 PM
Received 3 Votes on 3 Posts
I'm confused. You had two techs look at your furnace and gave you a diagnosis and they didn't replace the parts? You did?
