Water in oil tank
Old 09-24-07, 08:27 PM
Water in oil tank
Is there a product on the market that will dry up the moisture in an oil tank.
Something to what Heat(yellow bottle) is to gasoline?
Thanks
BOB
Old 09-25-07, 06:55 PM
KField's Avatar
The products that remove water from fuel tanks only remove a few drops per gallon at best. It should to be drawn out of an underground tank with a hand pump. Or gravity drained out of an above ground tank. Then a treatment can be added to hopefully remove the remainder. Sludge is bacteria that grows where oil meets water in the bottom of the tank so you don't really want to ignore the last of it.
Ken
Old 09-25-07, 07:44 PM
Ed Imeduc's Avatar
Wink
Might also check and see how ,where or when the water got in the tank. See that it dont happen anymore. Reset the tank so it stays out.
