furnace problem
Old 10-11-07, 05:59 AM
T
furnace problem
I'm at work, so i don't have the make of my furnace. Yesterday I noticed that my blower wasn't working, even when I turn it from "auto" to "on". I then noticed my furnace wasn't turning on, and my A/C unit wouldn't turn on. I checked the breaker, and that didn't help. I hear a click at the thermostat when I change between heat and cool, but get no response from the fan, furnace, or A/C. Any advise?
Old 10-11-07, 08:05 AM
T
Angry
The make of my furnace is a Comfort Maker RPJ2.
Old 10-11-07, 11:39 AM
Beachboy's Avatar
Received 1 Upvote on 1 Post
It sounds as though there is no power to the furnace. Are you sure the breaker is on the "on" position? Is there also a disconnect switch at the furnace someone may have flipped off? Is the door properly installed on the blower compartment? If this is a newer furnace, are there any codes being shown by the computer?
Old 10-11-07, 11:57 AM
T
The power is on at the breaker, and the switch is turned on. I was wondering if it could be a problem with the thermostat, since my outdoor unit for my central air won't turn on either. I don't know how old the furnace is, but it isn't new by any means. Everything worked fine two nights ago, and then it just stopped.
Old 10-11-07, 02:28 PM
Beachboy's Avatar
It sounds like to me you've lost your 24 volt control voltage. I'd suspect the 24 volt transformer in the furnace rather than the thermostat. Do you have a voltmeter than you are comfortable using to determine if you have 24 volts coming from the transformer?
Old 10-11-07, 02:37 PM
Ed Imeduc's Avatar
Wink
At the tstat jump R to G and see if the fan comes on. If so its in the tstat if not then on down to the transformer in the furnace.
