Mixed Wires on New Thermostat ???
Old 10-11-07, 02:52 PM
R
Tried starting the furnace this morning and it isn't working.
I installed a programable thermostat over the summer to reduce my AC costs and never checked to see if the heating was functional after the install. I don't know if I wired it correctly or not and want to rule this out before trouble shooting the furnace (which I don't know where to start).
I don't have the manual for my Carrier Weathermaker 9200 furnace, so I can't figure out if the thermostat wiring is the problem or not. Any suggestions out there?
The new thermostat is a Rite-temp 8035c from Home Depot, and I do have the manual for it. There is no trouble shooting info in it though.
Are there thermostat/controller wires for the furnace when contacted, opened, or grounded that should turn the furnace on to debug this issue?
Old 10-11-07, 04:29 PM
Grady's Avatar
Received 35 Votes on 33 Posts
Thermostat
There should be at least 4 wires from the furnace to the stat. Normally: Red, White, Green, & Yellow
Red should connect to either Rh or Rc (there should be a jumper between Rh & Rc on the stat)
White to W
Green to G
Yellow to Y
You may also have a fifth wire connected to C
