carrier NO HEAT model 58SSC075-JC
Old 12-07-07, 02:33 PM
Carrier unit blower starts ok then inducer motor & fan ok, glow bar lights seconds later a click then nothing and glow bar goes dim and it starts all over again.
prior to this happening i noticed the circuit board led showing a short flash then 4 slow flashes. Does anyone know what this means. I have already replaced the inducer motor and cage ( a noise issue ) it works fine. what is next?
Old 12-07-07, 08:08 PM
Either no gas or not enough gas is getting to hot surface ignitor or quickly enough, or the ignitor is weak.
You can take ignitor connector apart where the two wires go into the burner chamber and ohms test across the two wires going to the ignitor to see if it is good or likely bad. Any number under about 30 is in new condition and I have heard that up to about 65 it should still fire off. Can you make that test?
