Noisey Blower Motor
Old 12-11-07, 03:21 PM
Noisey Blower Motor
I have a York Diamond 80 that is 3 years old. When the heat or air kicks on there is a loud rattle that occurs until the motor stops running. It sounds like the squirrel cage is rattling. I took the blower assembly out and checked the cage. It looks good although some of the fins seem to be looser than others. I then wrapped the cage with electrical tape (to elimate possible fin rattle) and ran the motor again (blower assembly sitting on the floor) . I still can hear the rattle. Can faulty motor bearings cause the motor and squirrel cage to vibrate and create a rattle?
Old 12-11-07, 04:07 PM
No fins should be loose, of course. Your blower squirrel cage must now be out of balance.
Old 12-11-07, 05:58 PM
Absolutely, if some fins are lose then it is very likely that the squirel cage is out of balance and the furnace's sheet metal is likely to rattle... heck I can often hear a bit of ratteling just when the motor shuts off.
cheers
Old 12-12-07, 07:21 AM
Is it common for the squirrel cage to come out of balance? This furnace was working fine until about 3 weeks ago.
