Oil furnace troubleshooting
Old 12-16-07, 10:38 PM
I was doing a little wiring yesterday and in the process shut down power to my Thermopride OL5-85 oil furnace a couple times via the circuit breaker in my panel. Now, the furnace isn't working.
If it helps there are some pictures of the wiring here.
  • Nothing is running. Not the fan, the pump, or the burner.
  • The reset button has not popped up and the light does not come on if I use the lever to manually pop the button.
  • I've double-checked that I'm getting power to the fan center.
  • I'm not getting 24V between any of the terminals on the thermostat terminal board
  • Power is being supplied to the fan limit control leads.
  • The fan does not come on when I set the fan limit control switch to manual.
Any suggestions as to how I can go about troubleshooting this would be greatly appreciated!
Thanks in advance,
Mark
Old 12-17-07, 06:55 AM
At the fan center, did you check hot to gound or hot to neutral? Maybe you opened a neutral somewhere?
Old 12-17-07, 09:37 AM
You got it. I'd checked to hot to ground. Neutral wire was loose in the panel.
Thanks!!!
