Glow Ignitor stays on
Received 0 Votes
I have an Arcoaire RPJ II gas forced air furnace. The glow ignitor remains on all the time. I have only recently noticed it. There are no flashing code indicators. It is on throughout the entire heating cycle (call for heat, blower, normal ignitor on time, gas introduction, normal ignitor off time, furnace heats for however long, gas shuts off, blower shuts off). It stays on and doesn't react to the cycle. Any help would be appreciated, as I am sure this condition will shorten the life of the ignitor. Thanks.
Sounds like the ignitor control board is "stuck"... I don't know this brand, and what they use for control. Follow the wire from this ignitor, and post the make/model on it.
Received 0 Votes
The control board has the following printed on it:
The General 90
Inter City Products
Total Furnace Control
Model 50A50-110
Also, printed to the side is: 1380-686
Any help would be appreciated. Thanks.
The General 90
Inter City Products
Model 50A50-110
Yes, the relay turning the ignitor on is stuck.
You might get lucky by rapping on the ignition control to see if it will free up, but you might wind up breaking the control and having no heat, too.
Your solution is to replace the ignition control module.
Received 0 Votes
I'd first make sure that it indeed has electricity stuck going through it (easily verifiable with a voltmeter), and not caused from the ignitor being in the flame.
Received 0 Votes
The tapping worked. Thank you. I realize this may be temporary. Any idea on what a replacement would/should cost.
I tip my hat to this site. This is probably my 4th or 5th fix in my house.
I think ko is referring to replacing the ignition control module.
Hard to say on price. Shopping around will likely get you a cheaper price, but more important for a DIY installation is getting the right part. And it's not uncommon for updated parts nto have different ways of connecting the wires.
You can try a DIY replacement if you wish, but having an experience repairman do the job, inspect the furnace and do any need maintenance work has a lot to recommend it.
Received 0 Votes
Isn't that pretty much the way it always is though, these days? I told the person, "It be so simple if you just had the exact one I need." The person said, "Well, ya, but this is the new way they are making them now and they fit various furnaces, so that means you have to set he control module up to fit your particular furnace."
