fan speed adjustment?
Old 12-22-07, 04:56 PM
I had a Rheem Classic 90 Plus system installed at the end of the summer. The fan speed is the same on heat as it when a/c was on. My old sytem (Trane) the fan speed was slower in heat mode. I questioned the dealer about this as I don't really like it blowing that hard. He said that is the factory setting and it could damage the heat exchanger if he set the fan for a lower speed. Is this atypical of a 2-stage? I'd like to set it on the lower speed but don't want to void the warranty. The installer is a Rheem dealer. Thanks fo any info.
Old 12-22-07, 05:06 PM
Jay11J's Avatar
Is this a two stage furnace?
Model #?
The blower could be slower, but has to stay with in the temp rise range on the data plate inside the furnace.
Old 12-22-07, 05:11 PM
Furnace is 2 stage model RGRA04
Old 12-22-07, 05:40 PM
Jay11J's Avatar
I'd hate to break the bad news.. That is a standard single stage furnace.
Was the job bid for a two stage? if so, I'd call the dealer on monday and say you got a single stage furnace. not a two stage.
That is a small furnace, 45,000 BTU, and looking at the specs, the blower moves about 880 CFM on Med lo speed. Temp rise rated at 30 to 60˚.
Old 12-23-07, 04:43 PM
My mistake. I know it is a single stage. Is med-lo speed the factory setting for both heat and ac mode? Can fan speed be set on low without damaging heat exchanger?
Old 12-24-07, 08:35 AM
Jay11J's Avatar
YOu can set it down if you want.. Take a temp reading in the return,, and then on the supply above the a/c coil.
And let it run at least 10 to 15 min.
Take the supply temp - return temp will give you the temp rise.
