Is this furnace motor bad?
Old 12-28-07, 09:15 PM
How do I tell if a motor is bad? I pulled it out and there doesn't seem to be play in the bearings, it turns freely by hand. But, when power is applied, it has a hard time getting going. I have a multi meter. I'd like to check the resistance. What should the resistance be?
It's a 1979 Lennox.
Old 12-28-07, 10:07 PM
SeattlePioneer's Avatar
Check to be sure that you have 120 volts being applied to the motor.
Is their a capacitor near the motor? If so, the capacitor aids in starting the motor and could be the problem.
If you push the motor to get it started will it come up to speed?
Old 12-29-07, 11:28 AM
A relatively low number, but yet not 0, either. 0 would be a dead short. Every motor has some resistance. You can find that out by turning on your vacuum cleaner switch, unplugged, and hook meter to your plug ends at low scale ohms, and that will give you indication what I mean.
Old 12-29-07, 03:51 PM
There are 120 volts. But, no I don't see a capacitor mear the motor. How do I know if the motor is bad?
Old 12-29-07, 04:39 PM
If it has 120 volts to it you need to use your experience and judgement to decide whether it starts properly and comes up to an acceptable speed .
Not all fan motors have start capacitors.
Old 12-29-07, 04:44 PM
Of course you aren't going to have zero resistance, but resistance isn't what prevents a short on a motor or coil.
The coil creates inductive reactance when AC voltage is applied to the coil, which opposes the flow of current and acts like a resistance. Then there's capacitive reactance which does the same thing but is out of phase with inductive reactance.
Get inductive and capacitive reactance canceling each other out and you get zero reactance for a particular frequency, which is how a tuned cirvuit allows one frequency or radio station to be selected while excluding others.
That lesson courtesy of amateur radio license training forty years or so ago.
Seattle Pioneer
Old 12-30-07, 07:46 AM
But if 0 resistance is caused by winding short bridging windings to case, there is your dead short and 0 resistance. That is why I always ohms test between motor hot wire and the case to make sure there is not 0 resistance (0 resistance meaning 100 % continuity) between the two. Neither should there be any continuity between the motor's neutral wire and the case (on an a/c motor only). Should be done with wires disconnected to eliminate possible backfeed. Replaced shot motor successfully, due to this test, last year
