Chimney Dampner for oil heater? Auto
Old 01-03-08, 11:10 AM
P
Do they make a outdoor chimney dampner which opens automatically when the oil furnace runs and then closes when its finished heating? Would'nt this be beneficial to prevent heat loss ? the top sealing dampners i have seen are all manual types for fireplaces. thanks
Old 01-03-08, 07:40 PM
pflor's Avatar
What you're looking for is called an "Automatic Vent Damper"
I've seen (and installed) them for gas-fired equipment. Flue temperatures for oil-fired units are much higher.
Try this site. If they don't have them, they'll probably be able to point you in the right direction.
http://www.fieldcontrols.com/venting.php
Old 01-05-08, 05:22 PM
Grady's Avatar
Received 23 Votes on 21 Posts
Damper
Stack dampers for oil fired equipment used to be fairly common BUT, to my knowledge, they are no longer available.
